Case DC - What's next?
Jeff w/an H
09-01-2005 06:30:10
Ok - My Case DC was running...had a problem with the starter...got it rebuilt...now it won't start. It turns over great, but she won't even attempt to fire. What do I do next? Seems to be an electrical problem???? Thanks for the help.
Nick in Kansas
09-02-2005 18:15:02
 Re: Case DC - What's next? in reply to Jeff w/an H, 09-01-2005 06:30:10
Had the same thing happen to me this summer. I finally gave up, and pulled the "Old Gal" out of the way. As Sweety was pullin me, I popped the clutch, and the "Old Gal" fired right off. All I ever found was the magneto acted up. Ever since she fires on the first turn.
Mathias NY
09-01-2005 09:09:55
Here is a short list of some simple things I check when my tractor won't start:
Is there gas in the tank?
Is the gas turned on?
Is the choke working properly?
Do you smell gas when you are cranking? If you smell gas it's flooded, try drying the spark plugs.
Is the ignition turned on?
If you remove the plugs and crank over do you get spark?
If it is a magneto ignition, remove the wire that leads to ignition switch. This will simplify the electrical and elimiate any possible shorts with it.
Hope that helps some.....
