Year from serial # on CC
toomanycases
08-31-2005 23:33:16
Hi, I have a question on how you read the serial number on a CC to get year built? Ebay#7542936775 has a CC listed, serial # 0519805. Said it is a 1937 model. How?? I thought I knew how to determine year?? Good looking tractor in W Va. Also there is another CC listed ebay #7543029881. Dosen't look as good but I sure would like to have it. In W. Va, just too far(3000 miles) away. Chuck
toomanycases
09-01-2005 23:03:26
 Re: Year from serial # on CC in reply to toomanycases, 08-31-2005 23:33:16
Hi, Thanks for response. Problem is that he has a picture of the serial plate and it definitely has a 0 for the first number and model is stamped CC. Any thoughts? Take a look at the listing on ebay for me would you and ???. Could someone had a new serial plate made for it? Thanks Chuck
Brian in Ohio
09-02-2005 09:19:34
 Re: Year from serial # on CC in reply to toomanycases, 09-01-2005 23:03:26
You may want to contact the seller and have his get the serial number from the engine. It's located on the mag side, right where the head and block meet together, near the number 4 cylinder (closest to the fuel tank). There should be a milled spot about an inch square, and the serial number is stamped there. Bring that number back here, and we'll help decipher it for you.
Tractor looks like it would make a good project if you can get it cheap.
Joe (Wa)
09-01-2005 10:03:38
Serial # 0519805. The first 5 is probably a 3. That would make it 1935 model year.
Joe
John H-WI
09-01-2005 03:38:30
That isn't a valid number. Better email him and get the correct one. A C or L series never started with a 5.
