2670 Powershift problem
LJACHAR
08-28-2005 20:13:40
I have a 2670 that will not pull in any range in the 1st or 2nd powershifts, had the engine stall problem a month or so ago and had to adjust on the c-1 and c-2 valves but then all seemed to be ok after that, was out in the field the other day with the tractor running at rated pto rpm with the clutch pedal all the way in using the hydraulic to pack the stack of hay and all off a sudden it sounded like someone was trying to shift gear with no clutch , so i immediately brought the tractor to an idle and then the grinding stopped so increased rpm again and all sounded ok but when i went to go the was nothing in 1st and 2nd powershift, reverse and 3rd still work, but i limped it home after by passing 1st and 2nd powershifts, ANy suggestions or possible things that anyone my know of please let me know!! thanks!
jim handke
08-29-2005 06:14:19
 Re: 2670 Powershift problem in reply to LJACHAR, 08-28-2005 20:13:40
It sounds like you lost the C-1 clutch pack. It can be repaired without removing the powershift. But pulling that monster engine requires a stout a-frame.
