Case 430 - RPM meter
Jonathan PQ
08-28-2005 19:01:04
The generator on my Case 430 have been changed for an alternator before I own it. It has been fitted in place with an home made bracket, so I won't go back with the original generator. The problem is that my RPM meter is not connected at all. Is there any way to make it work again with an alternator? Thanks.
630 crazy
08-29-2005 17:40:37
 Re: Case 430 - RPM meter in reply to Jonathan PQ, 08-28-2005 19:01:04
I don't think you will have much luck hooking up the old original tach to the alternator. You may or may not know this but...the tach cable screwed into a gear drive on the end of the generator. Even if you got the gear drive and somehow got it hook up to the alt. It may not have the same pulley and the speeds would be all wrong. You might be able to rig up an aftermarket tach?
