Help, 580C starting problem
Bill
10-17-1999 05:12:49
I'm having a starting problem with my Case 580C, engine is a 207. Anytime the temp drops below 45 deg it will not start without a shot of starting fluid. Then when it starts the engine shakes like its missing and the exhaust dumps blue smoke for 2 or 3 minutes. After about 5 minutes running it runs smooth and the smoke stops. Just wondering if its time for some engine or injector work or should I just use it?? Thanks in advance, Bill
wayne
10-17-1999 20:50:08
 Re: Help, 580C starting problem in reply to Bill, 10-17-1999 05:12:49
Have you had the machine for a few years and had this trouble every Winter? How many hours are on it? A little more history may help. 8000 hours can cause those exact symptoms.
Larry
10-17-1999 17:45:44
You are experinceing what happens when you start a diesel engine in cold weather.Try useing WD40 instead of ether it is easer on the engine.It works best if you can spray it directly into the manifold.Also buy yourself a good block heater and plug it in about an hour before you start the engine.
Elmer
10-17-1999 05:30:02
I know a fella that was a service rep for Case industrial. He told me of that problem when they were new. He said that you can put a sleeve and piston kit from a 188 engine in and it will increase compression and improve starting. I never did this myself, but i would never doubt his word and he never led me astray. If you try it, check specifications on block bore sizes on both engines.
