Removing crankshaft pulley from 201
DCPULLER
08-28-2005 07:43:32
Anyone know how to remove the crank shaft pulley from the 201 in the 660 combine engine? Thanks, Dave
Bill from wisc
08-28-2005 07:55:52
 Re: Removing crankshaft pulley from 201 in reply to DCPULLER, 08-28-2005 07:43:32
Some years ago when I overhauled the engine on my 660,I couldnt get the crankshaft nut off. I had to weld a nut onto the crankshaft pulley nut and then use a impact to get it off. Then the pulley came right off. If you have the nut off already then just a little bit of heat should do the trick. It doesnt take much, so dont over do it. Bill
