Tractor pull question
Kirk-Tx
08-27-2005 17:30:48
I just got a DC running. Put new rings & had the head reworked but it is all stock. We are having pull locally & I was thinking of entering. Just wondering what gear would be best to pull in. I understand that they will weigh the tractors & I will be in farm class. It has factory weights on rear tires. Also what air pressure for pulling? Thanks for any advice.
Fergus
08-28-2005 03:36:38
 Re: Tractor pull question in reply to Kirk-Tx, 08-27-2005 17:30:48
A Case DC is quite well equipped to pull in it"s native state, especially the late units with the bigger bore engine. Low gear is fast enough to compete and low enough to spin out in almost all conditions. Bear in mind that. at least in our area, even the "stock" antiques are usually enhanced to the maximum limits of the class involved. Tires usually start around 10 lbs if the track is well prepared. The rest is on the job training to determine proper weight distribution. Front end is usually heavy enough to work well without a lot of adding.
Kirk-Tx
08-29-2005 20:53:46
 Re: Tractor pull question in reply to Fergus, 08-28-2005 03:36:38
Thanks Fergus I'll give it a try.
