Sc Magneto Timing
J Kelnhofer
08-27-2005 12:49:45
How do you time a Magneto? I took off the cap to install a new condenser on my SC and took off that little plate with the gear on it. Not sure where it is supposed to be at. Any help would be great. Thanks Josh
J Kelnhofer
08-27-2005 14:05:56
 Re: Sc Magneto Timing in reply to J Kelnhofer, 08-27-2005 12:49:45
I guess all I need to know is where that fiber gear should mesh onto the steel gear. Should there be marks on this fiber gear? The tractor ran fine before so everything else should be in time.
Glen in TX
08-27-2005 15:58:06
 Re: Sc Magneto Timing in reply to J Kelnhofer, 08-27-2005 14:05:56
Small gear in mag should have a dot on it and dist. rotor gear should have some beveled teeth to line up with dot.
J Kelnhofer
08-28-2005 09:51:38
 Re: Sc Magneto Timing in reply to Glen in TX, 08-27-2005 15:58:06
Thanks
