Eagle hitch blades
rob in MO
10-16-1999 18:22:29
I'm not exactly saying I want one, but how easy are eagle hitch blades for the smaller, older CASE tractors to find? Cost? I'm just curious!!!
TMAC
10-17-1999 21:16:43
 Re: eagle hitch blades in reply to rob in MO, 10-16-1999 18:22:29
I bought a scape blade and scoop bucket for my Case and I had to take them to a weldor for adapting them to the eagle hitch. The scape was too narrow and the scoop hitch pins too far apart. The cost of the fix was reasonable but If I had to start over again I would look for 3pt implements with 26" spacing between the lift pins.
Jerrie Lott
10-19-1999 18:18:39
 Re: Re: eagle hitch blades in reply to TMAC, 10-17-1999 21:16:43
You have to remember that there are four sizes of three point hitches Cat 0 Cat 1 Cat 2 and Cat 3. I have a post hole auger that fits right on my VAC and also a six foot scraper blade. I use my brother's Bush Hog on it all the time too and I don't have to modify any of them. I can also use them on my 1030 which is Cat 2 but if I take the sway blocks out and use bushings on the pins they work on it also
Jerrie Lott
10-16-1999 20:35:20
You don't need a special blade to fit an Eagle hitch, it is just a three point hitch in which the arms do not swing. I use a Jophn Deere blade on my VAC all of the time and when the snow gets too deep to pull I just take the sway block off of my 1030 and put it on there, of course I have to use bushings because the pins are smaller on Cat I than on Cat II hitches.
