Case 2594 power shift
Eva
08-26-2005 09:08:59
I have a 2594 with shifting problems. Some days it runs properly, but at other times it will not shift into gear. I believe it to be an electrical problem, but am unsure. I have taken the tractor to a Case dealership several times, and they have been unable to find and correct the problem. If you have had this problem or may know of possible solutions, please respond.
case trader
08-27-2005 15:00:44
 Re: Case 2594 power shift in reply to Eva, 08-26-2005 09:08:59
generaly the problem will be the printed circuit board i could actualy see a crack in mine would not work cold warm up fine around 200$
Can't even use my name
08-26-2005 14:01:51
I found an old topic here is the link.
08-26-2005 13:28:53
I think someone else posted a similar question a while back. Seems to me like it was a loose wire or a bad circuit board.
