DC Hyd Pump Leaking!
Glenn FitzGeral
08-25-2005 19:51:22
The hyd. pump on my DC leaks oil where the shaft comes out that the levers fasten to. It leaks even when the tractor is not running. How do I correct this problem? There must be a seal in there somewhere. I appreciate your responses. Glenn F.
Paul f
08-26-2005 06:05:52
 Re: DC Hyd Pump Leaking! in reply to Glenn FitzGerald, 08-25-2005 19:51:22
Glenn
There is an o ring and felt washer on each shaft.
Upper O ring o8569ab new # 238-5112
Upper felt o8398AB A30853
Lower O Ring o8416AB 238-5116
Lower Felt o8555AB A30879
Case Dealer had them about a year ago
Gle nn F.
08-26-2005 15:22:56
 Re: DC Hyd Pump Leaking! in reply to Paul f, 08-26-2005 06:05:52
I haven't attempted it yet, but is there any trick to getting it apart? What is the procedure? Thanks, Glenn F.
Case1950
08-26-2005 18:00:49
 Re: DC Hyd Pump Leaking! in reply to Gle nn F., 08-26-2005 15:22:56
Its been a while since I have done it but there is a small plate on the aft side of the pump. It has a pretty little eagle on it and held on by 4 small screws. Take this off and you will see what holds the arms on.
Make sure you drain the fluid first.
Case1950
Paul f
08-27-2005 06:40:36
 Re: DC Hyd Pump Leaking! in reply to Case1950, 08-26-2005 18:00:49
As the case manual likes to say removal is "self-evident upon examination"
"On dual valve systems, the lower valve control lever and shaft must be removed before the upper valve control lever can be removed."
para 299
Paul f
08-26-2005 06:03:05
Glenn
