Case L
daballmakes
08-24-2005 14:04:38
I am wondering if anyone can tell me how to get a waterpump for a 35 Case L to stop leaking? Is there just packing in there that a guy can buy and replace?
Thanks
Casenut
08-26-2005 12:51:16
 Re: Case L in reply to daballmakes, 08-24-2005 14:04:38
Yes there is graphite packing behind the nut on the shaft. Try to tighten the packing nut a little.
cheg
08-24-2005 18:24:46
Out of curiosity, did you turn down the grease cup? I purchased my Case L with a bad leaking waterpump. I took the tractor home and gave the grease cup a couple turns. The leak stopped and I have never had problems since.
AllanC
08-24-2005 22:15:52
 Re: Case L in reply to cheg, 08-24-2005 18:24:46
If it's like the later ones there is just a cast cap that runs against the housing for a seal. Running it, and grease are the fixes. If its leaking bad it may be corroded beyong help.
