David Brown 990
Joel Haack
08-24-2005 06:21:54
I just purchased a 990 selectamatic that had been sitting around for 15 years. I'm looking for some opinions on the 990's,pros,cons etc.It also runs choppy and seems to smoke black under a load.The tractor is in perfect condition and starts easy.I have changed the diesel but not the filters. Any thoughts on this or is that just how the older diesels run? Thanks.
Patrick Tercho
08-25-2005 16:05:42
 Re: David Brown 990 in reply to Joel Haack, 08-24-2005 06:21:54
If it's sat for 15 years I'd pull the valve cover off and make sure the valves are all moving. You may have one stuck open, or bent a push rod on one stuck closed.
rhudson
08-25-2005 08:45:30
filters are the cheapest gift any tractor could receive. its just that the CVA fuel system on the 990 usuall will not self clear any air that gets into the fuel system. you will have to bleed all the points as mentioned in the manual. i think(two on the filter houseing, two or three on the pump, each injector will have to be bleed) but that would be a good time to investigate the "choppy" problem. when the pressure line is loosened to an injector, fuel will stop flowing into that injector, that cylinder will stop firing. just as if you pulled a spark plug wire on a gas engine. if you notice a decrease in running quality, that cylinde was firing. if you don't notice a change in run quality, that cylinder was not firing. the little infrared thermometer can also be used to judge firing on a diesel..if the exhause port is not as hot as the others, that cylinder is not making as much power as the others.
both my 990's makes black under heavy loads. so do my JD's and MF's my feeling is thats normal. don't all diesels make smoke under heavy loads? max fuel but decrease in rpms, so decrease in air intake. rich condition. i've heard it called "loading up"
other than hydraulics, could it be that the 990 is the toughtest tractor ever built? well close to it anyway.
Bobby Pollard
09-05-2005 08:49:51
 Re: David Brown 990 in reply to rhudson, 08-25-2005 08:45:30
My 990 selectomatic runs perfect.As to your smoking problem,if you don"t have a valve problen,then you need to check the fuel system.Mine does not smoke at all,even under a heavy load.
dej(JED)
08-25-2005 07:51:39
Joel----- I have a 995 and they run great. It is really easy on fuel also. It shouldn't smoke as you have described. If it sat that long I am sure you need new filters.Also you could have stuff in the tank. Diesel tends to form peroxides as it ages.
Ritchie Leslie
08-25-2005 06:06:03
Replacing the fuel filters is some of the cheapest long term protection for your engine you can provide. Especially if the unit has been sitting around for a long time. Likely junk in the tank of some kind. But it will make no difference to your smoking problem. Change the hydraulic oil and filter at the same time to avoid problems with that. And if the gearshift boots are worn replace them to prevent water seeping into the gearbox/hydraulic system.
Smoking: Check to make sure that the cold start device is switched off. This is a small faucet-like control on the underside of the injector pump. Make sure it's in the out position (off). After that you might want to consider an injector job (about $400). Minor smoke is OK, thick black gouts are not good. How many hours has the unit on it?
joel haack
08-25-2005 07:38:49
 Re: David Brown 990 in reply to Ritchie Leslie, 08-25-2005 06:06:03
Thanks for your feed back. I will change my filters and check those other items.I'm not sure on the hours because the tach cable was broke.It did say 3500 before I fixed it.The tractor was used on a 15 acre field to pull a chopper for silage.The guy purchased it brand new and he died about 15 years ago and the tractor sat in a barn until I purchased it 4 months ago for 2250.The guys son that sold it to me said he had a new head installed a couple years before he died. A dealer did the work so I would think It was the right thing to do.I don't know any thing about diesels,but if it was a gas tractor I would think it was running to rich. The smoke is not to bad it's the choppy part that seems wrong.I would think it's fireing on all cyclinders because it starts so good.What do you think?
Bobby Pollard
09-05-2005 08:54:40
 Re: David Brown 990 in reply to joel haack, 08-25-2005 07:38:49
Hi,bobby again.If you know any salvage yards that have david brown parts,please let me know,I buy all the parts i can find.Thanks.
cj3b_jeep
08-24-2005 12:54:51
I have an 880 and it does not smoke until you load it really heavy, and then only for a few seconds. My guy at the Case dealer said not to mess with the filters unless it does not run right.
I've heard the worst thing about them is the hydraulics. Mine had a problem with that but I took care of it easily.
Good luck with it
dlmeon
02-06-2006 07:39:13
 Re: David Brown 990 in reply to cj3b_jeep, 08-24-2005 12:54:51
What was wrong with the hydraulics? I have a selectomatic 990 and the hydraulics work but are really slow and sometimes you have to put pressure on them to get the draw bars to go down. What did you do to fix your hydraulic problem?
thanks
