VAC Decal Placement
toolbox
10-16-1999 12:54:55
I have most of the decals figured out, but where do the following go?
1. "Important Keep cover type on gasket to prevent dirt or water from entering motor". I've seen pictures where this is on the valve cover, and on the air cleaner box.
2. "Be Careful stop Power Take Off before dismounting from tractor". I've seen this on the PTO guard, but think it actually is supposed to go on the right side fender.
3. What decal goes on the hood in front of the steering wheel, and what decal goes on top of the torque tube. (I could tell there were decals on my tractor in these locations, but my decal set doesn't have any more decals).
Mike
10-29-1999 10:06:29
 Re: VAC Decal Placement in reply to toolbox, 10-16-1999 12:54:55
The "PTO" sticker can go in several places. If your VAC is equiped with a PTO shield then it can be placed there. If there is no shield then place it on the top of the piston housing. If it's not equiped wiht an eagle hitch or hydraulics then it is placed on the top at the end of the differential. Originally there were 2 decals that were placed on top of the hood. One was the "GASOLINE" decal placed near the filler cap and there was a "safety first" decal that was placed just behind the small breather above the battery. The latter is not available in any kits that I know of nor do I remember the message it carried.
Marty
10-17-1999 14:23:37
I just finished a 51 VAC, including decals. Your #1 goes on the right side of the rocker arm cover. The PTO warning goes on the PTO shield. The only decal that goes on top of the hood is the gasoline only decal. Of course there are stripes and a CASE decal that go on the side of the hood, but this is it for the hood. There is also a CASE decal that is vertical that goes on the radiator or nose shield. I don't believe there is one for the torque tube. I have restored an SC and a VAC, and they essentially had the same decals. E mail me if you have more questions.
