Case tractor
FSmith
08-23-2005 14:14:33
Have a case tractor with no numbers. The plate on the dash is missing. I need to find the engine serial number to order parts. It is gas 4 cyl
JEANNIE
08-25-2005 04:26:11
 Re: Case tractor in reply to FSmith, 08-23-2005 14:14:33
I have a nephew that just bought a 1936 Case tractor to restore. I do not have any other info than that...I will get some today...but, just interested in that year and colors and what they looked liked. Do you know a site I can go to look at them?
Jeannie
Alberta Mike
08-24-2005 06:53:44
 Re: Case tractor (oops) in reply to FSmith, 08-23-2005 14:14:33
Oops, sorry, I responded back to your email contact and somehow I thought we were talking Masseys (I usually hang out over there too). My comments about the 33, 44 etc. wouldn't have made much sense, but the 444 was a Case yard tractor but it's only one cyliner. See ya, Mike.
Alberta Mike
08-23-2005 21:15:37
 Engine Type ? in reply to FSmith, 08-23-2005 14:14:33
Flathead or overhead valve engine?
Joe (Wa)
08-23-2005 16:21:56
All the VA series and most of the lower number series tractors have the engine serial nr stamped into the block above the starter.
There is no definite chronological relationship between the tractor serial nr and the engine serial nr but the engine nr can often be used to ballpark the model and build year(s).
Joe
John H-WI
08-23-2005 16:04:09
If its a flambeau series, IE- L, D, S the serial number is one the left side of the block where it connects to the transmission housing. Maybe you should go to the tractor photos and do a search on Case and see what yours looks like and the guys can help you narrow it down. Serial number for the V series isn't on the block but I believe it is on some of the older models too. Color will start to narrow it down.
Jeannie
08-25-2005 04:28:31
 Re: Case tractor in reply to John H-WI, 08-23-2005 16:04:09
Where do you go to see the tractor photos????
Dale(MO)
08-25-2005 06:39:54
 Re: Case tractor in reply to Jeannie, 08-25-2005 04:28:31
On the left side of this page, under the "Galleries" heading, click on "tractor photos".
Dale(MO)
