DC hydraulic oil
Glenn FitzGeral
08-23-2005 05:46:43
What oil viscosity do you folks recommend for the hyd pump on an eagle hitch DC? It will see little if any winter use here in Wisconsin. Thanks, Glenn F.
dctom
08-23-2005 06:28:10
 Re: DC hydraulic oil in reply to Glenn FitzGerald, 08-23-2005 05:46:43
N D 30 weight engine oil recomended
Scott KY
08-23-2005 17:42:47
 Re: DC hydraulic oil in reply to dctom, 08-23-2005 06:28:10
I have been using Hy-tran in the hydraulics on my SC's and DC's. I am afraid if I use 30 weight in them some of that oil would get mixed into the hydraulic system on some of my newer tractors. Do you think Hy-tran will cause any problems on the older Case tractors?
ChrisSC
08-24-2005 11:34:59
 Re: DC hydraulic oil in reply to Scott KY, 08-23-2005 17:42:47
Do you know where to find the engine spec.s for a 1953 SC Case. I've lost my IT manual and I need to set the valves and plugs.
Thanks,
Chris
dctom
08-24-2005 10:25:13
should cause no problem at all, the old tractors hyd pumps didnt have the close tollerence as the newer ones and sometimes dont work well with hy-tran but if yours dose go for it tom
