david brown heating problems
robert hall
08-22-2005 08:41:20
I have been having probablems over the years keeping the david brown cool. I think that I need a four blade fan instead of a two blade or just the gauge is wrong. I have put in several thermostates, new radiator and blow out the radiator often. Please any and all suggestions will be appriciated.
thanks,
robert
Patrick Tercho
08-22-2005 16:09:47
 Re: david brown heating problems in reply to robert hall, 08-22-2005 08:41:20
If you're still using the original gauge, either change the sending unit or replace gauge/sender with a mechanical gauge. We have a 990 that was chronic too warm no matter what, and this was the fix for us. If you change to mechanical, you will need to drill out the housing for the new sender to accomodate the larger size threads.
