49 CASE D info needed
Jed from Or
08-19-2005 22:12:09
I need the torque specs for the head studs and the timing for the roter in the mag any help
Tom Railsback
08-21-2005 18:23:25
 Re: 49 CASE D info needed in reply to Jed from Or, 08-19-2005 22:12:09
The correct setting for the head bolts is 75 ft lbs.
Timing the mag is fairly simple: Bring Number 1 up to ignition. You can check by removing a pipe plug just below where the starter mounts and turning the crank until a the letter "D" appears in the edge of the flywheel. Insert a spark plug wire in Number 1 hole of the mag and turn until it trips. Then witthout disturbing the mag, simply install it.
