VAC-15??
Camboted
08-19-2005 16:56:35
I ran into a VAC-15 with a serial number that started with an 80 etc. It looks exactly like a VAC-14. Is this a mistake, or did they make this model? What is the difference between it and a VAC-14?
martin in DE
08-20-2005 16:53:05
 Re: VAC-15?? in reply to Camboted, 08-19-2005 16:56:35
The front end is narrower and the front spindles are shorter. I believe the rear axle housing is narrower than a VAC-14. The fenders are different also,the lights are mounted low in front of the front axle.On page 223 of Full Steam Ahead,Erb has miss identified a VAC-15 as a VAC-14.If you see these tractors side by side, you will quickly see the difference. Martin
mj
08-19-2005 18:15:21
The VAC 14 is a low-platforn version of the VAC 13 which replaced the earlier adjustable widefront VAC. The VAO 15 was a low-platform, orchard type version of the VAC 13. Based on the older VAO it had a shortened steering column, lowered seat and platform and adjustable front and rear tread width.
Joe (Wa)
08-19-2005 19:10:12
 Re: VAC-15?? in reply to mj, 08-19-2005 18:15:21
I have only seen two 15's and they were low profile VAO's. Check the tag, should be Rock Island built and 60?
Joe
dctom
08-19-2005 17:09:02
ted, both were made 14 and 15 you sure the serial number didnt start with 60?? tom
Camboted
08-19-2005 18:07:56
 Re: VAC-15?? in reply to dctom, 08-19-2005 17:09:02
Tom, what was the difference between a 14 and a 15? I looked as close as I could and it sure looked like an "80". Did Case ever make an "80" series of serial numbers? Do you have VAC build cards?
dctom
08-20-2005 09:15:26
 Re: VAC-15?? in reply to Camboted, 08-19-2005 18:07:56
ted, MJ explaioned them well, no i dont have thoes cards and yes there was 80 numbers racine built S_D_LA 53 and 54 tom
