DC magneto
Tod Wagner
08-17-2005 18:51:08
I've got a '39 DC with a 4CMA magneto. Does anyone have a diagram of this one? How do I get the points out for replacement? The wire leading to the points has broken off. Does it lead to a condensor? It's a great running tractor.
thanks
Glen in TX
08-17-2005 21:29:44
 Re: DC magneto in reply to Tod Wagner, 08-17-2005 18:51:08
Todd, The wire from the points goes inside to the coil. Take the top cover with Eagle off and you'll see the terminal on side of coil and condenser also. If you need to replace that wire can just pull the whole breaker box off to get at points. That old wire with old brittle varnished fabric insulation is a problem and needs to be replaced anyway. Cotter pin has to come out for contact lever to come out. Email me and I can send you a parts breakdown of the 4CMA. Also have copies of the Case mag repair manual.
