990 selectamatic 3pt problems
Aaron H
08-16-2005 19:42:12
Hi all, The 3pt arms wil not work on my 990 the externals are working to raise and lower a hyd, cylinder though. I have tried all three positions of the selectamatic, no go. Where should I start looking? Thanks
William Ted Belue III
08-29-2005 16:31:18
 Re: 990 selectamatic 3pt problems in reply to Aaron H, 08-16-2005 19:42:12
Your problem will most likely be in the position control valve assembly. It is located on the right side inside the axle housing. It can be partially viewed by a cover with two scews on the top. The valve, sorry to say will most likely have to be removed. Unless you have a sevice manual and want to get pretty deep i would not suggest you tackling it youself
