Is this really a 1938 Case L?
Canuck_case
08-15-2005 20:32:43
Recently picked up a 1338 case L ( according to the serial number). Having looked at pictures of other Case L's in the thirties, they all have a square front (where the CASE logo is. Mine is rounded. Could Canadian Case L's be styled differently. I have digital picts but don't know to post them here. Will send to interested responders or if someone can help me post them on this forum I will.
Thanks
KD
Here's the picture...F-I-
08-16-2005 14:08:39
 Re: Is this really a 1938 Case L? in reply to Canuck_case, 08-15-2005 20:32:43
third party image
Here's your picture!
Brian in Ohio
08-16-2005 15:40:26
 Re: Is this really a 1938 Case L? in reply to Here's the picture...F-I-, 08-16-2005 14:08:39
That's an LA. Even the Model Ls that came out after the LA hit the market had the square top radiator. But even the fuel tank in the picture is rounded, signifying that that's an LA.
If nothing else, try to get the complete serial number and have DCTom look it up for you...
John H-WI
08-16-2005 12:05:11
What is the serial number. Never heard of a rounded nose L. Would surely like to see a picture. Do you have your pictures loaded to your pc?
canuck_case
08-16-2005 12:50:33
 Re: Is this really a 1938 Case L? in reply to John H-WI, 08-16-2005 12:05:11
The serial number is 420????? L. I posted a picture just now under tractor Photos "1938 Case L" Also I pasted the link to the pict below.
L.C. Grey
08-16-2005 17:06:54
 Re: Is this really a 1938 Case L? in reply to canuck_case, 08-16-2005 12:50:33
I'd wonder where you got the number from on the machine.
If you took it off the block it could indicate someone harvested the engine or block from an ealier L, They were exactly the same inside and out except for starter provisions.
If you got the number from the tag on the dash, I'd find that rather confusing. Surely someone didnt restyle an old L and change the tag too?
If the tag is present, does it say "L" or"LA"?
AllanC
08-17-2005 16:15:06
 Re: Is this really a 1938 Case L? in reply to L.C. Grey, 08-16-2005 17:06:54
There should be a number on the rear flange of the engine on the left side. It is the same as the tag number - assuming it's the original block. post it and we can tell You. But it's a '39 or later LA by the pics. Does it have a 4th gear??
Glen in TX
08-17-2005 21:51:53
 Re: Is this really a 1938 Case L? in reply to AllanC, 08-17-2005 16:15:06
That's what I thought? The L had 3 speeds and LA had 4. Pic looks like a LA to me too.
canuck_case
08-19-2005 19:40:31
 Re: Is this really a 1938 Case L? Here are tje ser in reply to Glen in TX, 08-17-2005 21:51:53
The tractor is 3 speed. The serial number on the tool box is 4210885 Size - L. On the right side of the engine is athe number 4862A.
Glen in TX
08-19-2005 21:01:02
 Re: Is this really a 1938 Case L? Here are tje ser in reply to canuck_case, 08-19-2005 19:40:31
Sounds like it is something different or a L by the number but still looks like LA?? LA numbers started at 5400001 according to blue book I have. You should let DCTom look it up for you to see what build card says?
