barnfresh1945LA clutch prob ?
WA in IA
08-15-2005 20:12:30
i have 45 LA been setting for years . starts and runs ok but clutch housing has lots of engine oil are my suspions correct ? bad rear seal . have pulled wrenches for years on tractors just not anything like this old LA its a cool old orignal LA that i want to restore thanks for all info.
Alan T.Lewis
08-15-2005 21:09:58
 Re: barnfresh1945LA clutch prob ? in reply to WA in IA, 08-15-2005 20:12:30
Hello WA in IA,
You mention that your tractor, which you think is an "L", and that it has plenty of engine oil in the clutch housing, please don"t worry because all CASE models, "L","LA","D" "C" "R" "S" tractors all have a "Twin Disc" oil bath clutch. The oil is fed from the rear of the crankshaft through a drilled oilway, and runs at a constant level and as it is pumped in it goes back into the crankcase via a return oilway so you have no worries there. Just drain the clutch housing each time you drain the engine sump.
You also mention about the radiator top tank being a rounded shape, you either have an "LA" or some body has replaced the top tank of the "L", is the tractor 3 or 4 forward speeds ???, if it is an "L" it will only have a 3 speed trans. or if it"s an "LA" it will have 4.
Hope that this is of some help to you.
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
