VC engine
Nedd
08-15-2005 14:47:23
Is the Continental engine in the VC the same as those in Ford 2Ns and early 8Ns? I think some early Massey Ferguson combine had them too.
Alberta Mike
08-16-2005 07:03:27
 Re: VC engine in reply to Nedd, 08-15-2005 14:47:23
Definitely not, the Continental in your VC is an F400 series Continental, probably the 124 version but the 140 and 162 versions will drop right in too (I have a 140 from a MF 34 swather in my V. Massey used them in a lot of tractors and other stuff. Lincoln used them in welders. A ton of other industrial applications too. I believe the N series Fords were a Ford engine built by Ford and not really similar at all other than being a flathead 4 cylinder. I'm curious, why are you asking the question?
Nedd
08-16-2005 09:14:04
 Re: VC engine in reply to Alberta Mike, 08-16-2005 07:03:27
A couple, one for sure, of the valves need to be replaced. We have a continental motor from a massey super 35 combine that we parted out and was wondering if I should even bother tearing into that motor to find out. Also have some neighbor that have several old ford parts tractors. Not sure if I could find new valves or not.
Duner Wi
08-16-2005 09:55:27
 Re: VC engine in reply to Nedd, 08-16-2005 09:14:04
My Sealed Power catalog lists all sorts of internal engine parts for the VC with Continental F 124 engine. Your local auto parts store should be able to help.
