J. I. Case plow identification
Patrick (Mich.
08-13-2005 20:49:49
At auction today, I bought a four bottom semi-mounted Case moldboard plow and am trying to positively identify what model it is. It is an early 70's model, with the block "CASE" letters that came after the Tenneco takeover. The rear wheel has steering linkage, with the hydraulic cylinder mounted back by the tail wheel. The plow is of a mono-beam construction, by which I mean the main frame is composed of a large (4"x6") steel boxed beam. I cannot find any sort of model tag riveted to the frame, but from what I have studied in my Case books it sounds like a model 500 plow. Does this seem right? Is there any place to look for specific numbers stamped on the frame, etc?
1031D
08-14-2005 22:38:00
 Re: J. I. Case plow identification in reply to Patrick (Mich.), 08-13-2005 20:49:49
sounds like my good ol 700 plow.
Patrick (Mich.)
08-14-2005 20:27:36
Upon further examination, I have discovered some more details. The bottoms are spring mounted. On the back side of the moldboards, they are stamped "EXC 16" with "SC" stamped below that. The trashboards have "T33718" stamped on them, and the trashboard bracket (which bolts to the frog) has the number "T-1878" cast or forged on it. Also the plow shares are the three bolt type, with a 1/2" bolt leading and two 3/8" bolts following.
