DC cranks but won't pop
Kory Kroeger
10-14-1999 18:09:13
My '53 DC cranks but won't run... It has good spark and gas, but won't fire. Even if I pull it she still won't start. Choking it doesn't make any difference.
Any help would be greatly appreciated!
Thanks, Kory
Jerrie Lott
10-15-1999 17:56:50
 Re: DC cranks but won't pop in reply to Kory Kroeger, 10-14-1999 18:09:13
Are the plug wires on the right spark plugs I know that sound silly but people have been known to overlook the simple thinking it must be something more complicated. Maybe you went the wrong direction aroung the cap with the wires
Larry
10-14-1999 20:19:05
If you flooded the engine trying to start it you may have washed all the oil off the cylinder walls.If this happens you won't have enough compresion to start it.Try putting some light oil in each spark plug hole.Better check to make sure some of the gas didn't make it into the crank case.
Jim
10-14-1999 19:50:27
Have you tried shooting W/D 40 in carb? It`s less dangerous than starting fluid and will run the engine, at least long enough to show valves and compression are ok. If it runs on W/D the jets in the carb may be plugged. An engine needs a air/fuel mix,,,compression and a ignition sorce to get things going.
Hope this helps,,jsl
