is it true
900Dave
08-12-2005 10:49:57
that you can get 504 cubes out of a 900 just by changing piston and sleeves if so what model are they from
Thanks
Dave
mike's600
08-12-2005 18:06:13
 Re: is it true in reply to 900Dave, 08-12-2005 10:49:57
You can get a 1000 cubes with a few changes.
900Daver
08-13-2005 07:26:46
 Re: is it true in reply to mike's600, 08-12-2005 18:06:13
Mike what is the few changes thats alot of cubes do you run that on gas or diesal.my email is there
Thanks
dave
mikes'600
08-14-2005 18:41:54
 Re: is it true in reply to 900Daver, 08-13-2005 07:26:46
I was being alittle facetious, takes alot of work and alittle cabbage.Maybe i have that reversed.Anything is possible! I'am running mine on gas.I have a big diesel (451'ish) pulls good. I don't see much of a advantage with anything over 504 using the stock heads and pump.
Camboted
08-12-2005 20:34:57
Mike, "Don't kid a kidder". HOW do you get 1000 CI out of a 600????? Please tell me. Just curious.
mike's600
08-14-2005 18:44:34
 Re: is it true in reply to Camboted, 08-12-2005 20:34:57
There was one for sale in the photo ads a few monthes back.
casepuller1
08-13-2005 05:48:33
5.375 bore 7.5 in stroke gets you 1000+, but there are some bigger ones out there. Mine has an 8 in. stroke and more bore
mikes'600
08-14-2005 18:46:37
 Re: is it true in reply to casepuller1, 08-13-2005 05:48:33
you doing good with those MM GV1's. They have some big cubes.
