Rusted wheel followup report and wheel rim questi
Casekernel
08-11-2005 19:30:17
Went out this morning, put the cap back on and left it loose. Backed it up and heard a "pop" as the keyed half broke free. One reason the weight of the tractor did not break it loose before, I think, was because I had a landscape rake attached and on the ground so that probably took some weight off. Anyway thanks for the help!
Another issue. I've been cleaning up the rims and one has a badly rusted area (corroded area around valve stem), no doubt from tire fluid leaking in its history. I'm thinking it might be thin in that spot. Won't know for sure until the tire comes off, but looks like there may be a couple of small holes rusted through also. Is there any way to repair this by brazing, patching or other means? If so, what?
Would brazing warp the rim? It looks like there's good metal around the weakened area. Also, planning to clean off loose and surface rust, but not take all rust off and then use a product called "Rust Treatment" (Permatex), then fill pitted spots, prime and paint. Feedback Please!
Jerry W
08-14-2005 15:22:25
 Re: Rusted wheel followup report and wheel rim qu in reply to Casekernel, 08-11-2005 19:30:17
I've fixed many rusted out rims. I cut a piece of steela little bigger than I need and roughly form it and them started arc welding and hammerin' like DCPuller says. One rim I fixed went egg shaped so now I like to have them mounted when I weld them.
Jerry
FiremanJohn
08-12-2005 11:08:59
I had a light rust area around the valve stem. Fixed it by welding a flat washer into the rim, even has a built in valve stem hole.
DCPULLER
08-11-2005 20:45:17
I've fixed some bad rims before by welding a patch to the inside. Use a wire feed and hammer down the metal as you weld it. Drill a new hole for your valve stem in a different spot on the rim. Put body filler over outside of rim and sand smooth. DCPULLER
