VAC torcktube fluid level
cleatusj
08-11-2005 19:09:44
If one is using auxilery hyd. resvore how much fluid should be run in torcktube?
cleatusj
08-12-2005 19:27:14
 Re: VAC torcktube fluid level in reply to cleatusj, 08-11-2005 19:09:44
You miss understood, I know longer will use torktube as a hyldraulic tank. So how much should I leave in there to keep seals good.
Joe (Wa)
08-12-2005 20:00:47
 Re: VAC torcktube fluid level in reply to cleatusj, 08-12-2005 19:27:14
For tractors not equipped with the low pressure hydraulic system, 2 gals SAE 90 was recommended for torque tube lube of drive shaft bearings (and belt pulley gears if so equipped).
I would use the same oil as is presently in the transmission. Assume you have removed the hyd pump, it won't live long trying to pump gear oil.
Joe
cleatusj
08-12-2005 20:29:39
 Re: VAC torcktube fluid level in reply to Joe (Wa), 08-12-2005 20:00:47
Joe, I'm running an axuilty tank on upright of FEL, to keep from sucking air with higher preasure pump. Also have no belt drive.
Joe (Wa)
08-11-2005 19:48:18
The torque tube holds about 2 gals. You can run it at a little higher than the normal fill plug lip level. May have to plumb the breather higher to cut down on the mist mess.
Joe
