Question for DCTom
Case1950
08-11-2005 17:08:14
DCTom,
I remember a post a long time ago about your method for unsticking a engine. Something about hooking up hyd. to a spark plug hole and forcing the piston down.
How do you make the adapter for this? Weld a hollowed out spark plug to a hyd. fitting? Do you think a DC will have enough hyd. pressure to unstick another DC?
Thanks,
Case1950
dctom
08-11-2005 18:23:13
 Re: Question for DCTom in reply to Case1950, 08-11-2005 17:08:14
case 1950, yes that is what i use,knock the porcelin out of a spark plug and weld on a 1/2 " coupling, i have put a 5/8nut on top of the releif spring in the hyd pump and have plenty of pressure, you must make sure the valves are closed ahd hold and the piston is up i have broke a lot of tractors loose this way from a g jd to a vac case and all in between tom
dctom
08-11-2005 18:23:05
Case1950
08-12-2005 06:38:28
 Re: Question for DCTom in reply to dctom, 08-11-2005 18:23:05
I will give it a shot. I"m going to let the tractor soak a few more weeks and try out your method. Sounds like a great idea to me.
Thanks,
Case1950
Nedd
08-12-2005 07:16:00
 Re: Question for DCTom in reply to Case1950, 08-12-2005 06:38:28
I knew a guy who broke a crankshaft on a 2 cylinder JD doing that. He told me to disconnect the connecting rod before trying it. Of course it was a JD and that might be why it broke. I would think the line on a compression tester would also work.
dctom
08-12-2005 07:34:28
 Re: Question for DCTom in reply to Nedd, 08-12-2005 07:16:00
I think if yopu bend or break anything with 1200# of pressure what ever you bend or break is junk anyway tom
