Vac Hydraulic,s
Rags
08-11-2005 08:38:00
The hydraulics on my 1950 vac are very spungy & I get quite a blow back through the filler hole.Also losing fluid while tractor is parked.Never been into this befor.Where do I start? Thank`s.
Joe (Wa)
08-11-2005 09:46:10
 Re: Vac Hydraulic,s in reply to Rags, 08-11-2005 08:38:00
The only place to pull air into the system is the pump suction tubing or less likely the pump shaft seal.
The fittings may be loose, ferrules slipped on tube, suction pickup not properly positioned below normal oil level, etc. If the tube fitting on the pump is tight, Temporarily cover it with plumbers putty to determine if that is your leak.
If pump shaft seal is leaking, the pump will partially drain into the engine oil sump each time the the engine is stopped.
Loss of torque tube oil level w/o external leaks is via the drive shaft seals into the transmission sump or at a much slower rate into the engine sump via failed pump shaft seal as above. Check the transmission & engine oil levels.
Joe
