Case DC - Won't start - I messed it up!
Jeff w/ an H
08-11-2005 07:49:50
Ok - I am new to this. Bought a Case DC and it runs pretty good. I was trying to adjust the gas at the carb because I can"t get it to start now. All of a sudden now it quits turning over (something caused it to stop cranking). What do I do? I am not much of a mechanic, but will try it out! Thanks for your help/suggestions.
Jaker2
08-11-2005 13:02:15
 Re: Case DC - Won't start - I messed it up! in reply to Jeff w/ an H, 08-11-2005 07:49:50
My guess is the starter is jammed against the ring gear. Either put the tractor in gear with the clutch engaged and rock the tractor back and forth. If that doesn't work take the started off, when it is removed take a pry bar and roll the engine over.
Coloken
08-11-2005 10:30:00
If it was cranking befor, chanches are its the battery cable connections.
POP
08-11-2005 08:47:31
IF IT'S A 6 VOLT BATTERY THEY TURN OVER REAL HARD BIG ENGINE FOR 6 VOLTS
todd hamilton
08-11-2005 09:35:25
 Re: Case DC - Won't start - I messed it up! in reply to POP, 08-11-2005 08:47:31
Hand-crank it!:^)
Jeff w/an H
08-11-2005 10:30:03
 Re: Case DC - Won't start - I messed it up! in reply to todd hamilton, 08-11-2005 09:35:25
Yeah - I tried hand cranking it. No-go. I must've done something though, cause I could get it to crank no problem - then after I was messing it wouldn't even try. I'm not sure what to check.
