DC Puller Hey DC Tom
mike's600
08-10-2005 16:55:07
Hey DC Tom,I have a question on speed. My DC puller is to slow in first gear( spinn out ) to fast for 3.0 mph pulling in 2nd gear.Did case make different drive sprocket tooth counts? Can you tell any other way short of taking the tractor apart and counting the teeth. I have two parts tractors.I'am running 13.6x 38's currently.
Thanks for the help
dctom
08-10-2005 17:15:56
 Re: DC Puller Hey DC Tom in reply to mike's600, 08-10-2005 16:55:07
mike i would bet you have 38 tooth in him now, no way of telling except removeing rear cover or motor lift, if the sprockets stick out beyond the flange they are 38 if just in side they are 31 tom
dctom
08-10-2005 17:13:07
mike, yes they did 38 tooth standard for DC 31 tooth special for DC and standard for D and 25 tooth for fast DI's I used to run 31's in mine till they lowered speed limit to 3 mph than i couldnt throttle down enough to stay under the horn and maintain power, maybe you need 15.5 or 14.9 tires tom
mike's600
08-11-2005 19:46:59
 Re: DC Puller Hey DC Tom in reply to dctom, 08-10-2005 17:13:07
Thanks for the help, we were thinking 14.9's.
Mike
