VAI hyd
Goldie
08-08-2005 13:20:21
Does anybody know the capacity of a vai hyd pump, gpm and psi.
thanks
mj
08-08-2005 20:17:47
 Re: VAI hyd in reply to Goldie, 08-08-2005 13:20:21
The low-pressure pump (mounted on the backside of timing gear cover) is rated at 7 gpm and 900psi while the high-pressure pump mounted on the belt pulley housing is rated at 2000psi and 2gpm.
1031D
08-08-2005 18:33:51
belt pulley powered or engine drive?
