LA Clutch Oil Questions ...
Alberta Mike
08-08-2005 07:58:47
Couple of questions about the clutch oil in an LA Case. First, is the clutch oil and the engine oil the same oil? Or are they separate chambers with their own oil supply? And if they are the same, if I drain the clutch oil out (2 quarts), does the engine oil keep draining through the same drain plug as the clutch oil? Last question is this .... how do I add the 2 quarts of clutch oil back into the clutch housing? I have a manual but I can't seem to find the answer to those questions.
dctom
08-08-2005 08:42:58
 Re: LA Clutch Oil Questions ... in reply to Alberta Mike, 08-08-2005 07:58:47
aboth the same oil, drain crank case and clutch at same time and add extra quart for clutch it cerculates between clutch and pan when running tom
