V and VA Parts Interchangeability
mj
08-06-2005 20:40:51
Anyone know if the clutch disc, pressure plate
and throwout bearing from a V will fit a VA
series?
Alberta Mike
08-07-2005 18:21:55
 Re: V and VA Parts Interchangeability in reply to mj, 08-06-2005 20:40:51
There are a few interchangeable parts bwtween the V and VA series, although most references will tell you otherwise. I personally used a clutch shaft, clutch shaft front housing retainer, throwout bearing and throwout mechanism and rod from a VA in my V Case. They are identical, I had them side by side and measured them. I would assume that the clutch plates/discs are the same too but I can't vouch for that.
mj
08-08-2005 20:23:13
 Re: V and VA Parts Interchangeability in reply to Alberta Mike, 08-07-2005 18:21:55
Thanks for the info that will help a bunch!
1031D
08-06-2005 21:25:55
All the books and spare parts I have say they won"t. I have a good used throwout bearing if you need one.
mj
08-06-2005 22:05:01
 Re: V and VA Parts Interchangeability in reply to 1031D, 08-06-2005 21:25:55
Thank you, sir.
