Interchangeability
Quincy
08-06-2005 20:24:37
Another ignorant question: Is the propane system on a 811 the same as the one needed on a 413? The carb will bolt on and the tank mounts are identicle. My 413 was robbed of it's lp gas system and I found a 811 with the system intact. Thanks guys.
buckmaster 700
08-08-2005 15:32:01
 Re: Interchangeability in reply to Quincy, 08-06-2005 20:24:37
it will work put er on
S.jewell(630 crazy)
08-07-2005 14:30:08
I am not a 400 or 811b series expert, but when the number change took place in 1957(58) most if not all of changes were cosmetic. If you have a parts book on one or the other you could see if the part#"s are the same. If you don"t have the parts manual maybe someone on this board could look it up for you.
