Case 401 Diesel
Mark Bergloff
08-06-2005 09:32:25
I'm finally doing a full rebuild on my 401 diesel. I've pulled the heads and there was a major leak on the number 4 cylinder (head gasket). I'm assuming the heads are also full of cracks once I get them to my head shop. I've noticed there are quite a few different casting numbers for the old powercell motors. My question is, is there any advantage to using a different casting number if I have to replace the heads. I'm looking for more power like any other red blooded american. Do the late model 830 heads have larger valves, better ports etc. Could I use a 930 or 1030 head? Any problems with head or manifold studs. I'm a machinist/moldbuilder by trade so I can do some machining if needed to make them work.
Also, it looks like 4.25 is the largest sleeve you can put into the 401 block. You can't put a 4.375 bore sleeve in the 401 can you? Any other advise for the rebuild, more power. How about turning up the pump or different injectors?
Any recommendations on a good rebuild kit?
Thanks in advance,
Mark
buckmaster 700
08-08-2005 15:39:33
 Re: Case 401 Diesel in reply to Mark Bergloff, 08-06-2005 09:32:25
830 heads wont fit it email me or call 812-394- 5704 i can get ya going i pull a 1958 701B diesel same as a 401
Camboted
08-06-2005 14:50:20
add a turbo
Don Rudolph
08-06-2005 11:33:37
My pump was shot so we put an 800 pump on it that is 1800 RPM as opposed to 1550 stock. Also used the 4 1/4 kit from Don Livingston. Still a little disappointed with the power. I thought it would blow away a DC but it doesn't.
