570 case backhoe/loader with dsl. engine
Frank Learned
08-04-2005 12:33:17
This unit has am. bosch pump. what is proceedure to r&r pump and retime? thanks in advance, frank
jc marleau
08-04-2005 18:12:34
 Re: 570 case backhoe/loader with dsl. engine in reply to Frank Learned, 08-04-2005 12:33:17
Yes Roger there is a backhoe 570 LXT , they made that backhoe the same year they did the 580L more or less the same machine with different option. equip with a cumming engine 4,390.
Roger (Mi)
08-04-2005 15:57:58
 Re: Do you mean 680 Case backhoe/loader? in reply to Frank Learned, 08-04-2005 12:33:17
The 570 was the agricultural tractor for Case. The 580 was industrial. All of the (570/580) diesel tractors that I've seen came with either 188/207 diesel engines with Roosa Master injection pumps. The Bosch pump could be found only on the 336 CID 680 Case loader/backhoes.
Roger (Mi)
08-04-2005 21:11:05
 Re: Obviously, I've old school.. in reply to Roger (Mi), 08-04-2005 15:57:58
Guess I'm old school on newer Case equipment. Numbers get confusing when Case uses the same numbers on basically the same kinds of equipment. Don't know much about Cummins diesels in newer Case equipment. Thanks for the info.
