VAC question
Jerry W
08-03-2005 06:57:44
When did they change the bolt pattern between the transmission and the rear end on a VAC. My parts book does not show a split on this - only Eagle Hitch or non Eagle Hitch rear ends.
Jerry
1031D
08-03-2005 20:39:41
 Re: VAC question in reply to Jerry W, 08-03-2005 06:57:44
My parts book lists several different rear end castings, but they all sub into eachother as time goes on. In the later years, you could only buy a new eagle hitch style rear end and they sold you special bolts and gaskets to seal off the eagle hitch holes. The rear end to trans case gasket is also the same part number. I can't recall ever having 2 differnt rear ends that wouldn't swap, unless you have a VTA2729 or VTA2821 trans case which is VAH only.
Jerry W
08-04-2005 05:08:47
 Re: VAC question in reply to 1031D, 08-03-2005 20:39:41
What I have is an early 1949 VAC with a rear end that will not bolt up unless I remove 2 studs and drill 2 new holes.
This tractor looks like it was made up of at least 2 tractors as it has a VAI front end and a few other parts from a VAI.
Jerry
1031D
08-04-2005 22:43:05
 Re: VAC question in reply to Jerry W, 08-04-2005 05:08:47
I havn't had that problem yet. I know the VAH/VAS transcase wasn't relieved for the bullgears and the bottom 2 studs are about 6" higher. I have a 1946 VAC, a 1945 VAI, and a 1954 VAC-14 in my shop right now, and I measured them, all the same spacings. Can you post a picture of them?
