another tractor splittig question
INCase
08-02-2005 09:49:00
Has anyone used or made a set of "splitting stands" to work with a 730? I"ve seen several types out there but that group of tractors (400-830"s) does not have any side mounting holes near the back of the engine to mount splitter stands too. The tranmission shouldn"t be a problem as it has side mounting holes. THANKS!!
Eric Wise
08-09-2005 12:58:26
 Re: another tractor splittig question in reply to INCase, 08-02-2005 09:49:00
After using blocks and jacks for years, we made some stands that worked so well that we offered them for sale. They can be bolted/clamped to almost any surface including pipes and castings. Keep in mind that these are commercial grade stands for heavy use. The material is heavy and they are powder coated. I can send information by email if interested.
wayne2
08-08-2005 08:21:32
I've found specialized tooling(cutting torch, large assortment of bolts,smoke pouring out my ears) things can be done. Cold beverages a Must. Luck, wayne .
Bob/wis
08-03-2005 04:29:43
We made a adjustable roller set for the front. It craddled the oil pan in back just ahead of the split point. Then on each side we had 2 sets of braces running to the front above the axle. This was on a 930 CK. It worked great. On each leg on the back we had old screw jacks off New Idea mounted corn pickers built in to roll the enigne to either side. Also the braces to the front wherre the support brackets that held the sub frame of the picker on to the front of the tractor too. I may have some pics around here of it. The frame work we used was from a New Idea elevator. We cut the axle intoo and narrowed it up and weld it back together. We used rims with no tire so there was no rubber tire to squezze.
Later
Bob
Tom (Ks)
08-02-2005 18:32:23
The stands we had at an old dealer had a big stud on each side of the stands that stuck into the hole that the largest engine to clutch housing bolt was located. We removed the largest bolt on each side, slid the stand in and installed a locking plate around it and then removed all the other bolts and split the tractor. We took off two oil pan bolts and installed the plate there and put the bolts back in to hold it. Worked on everything from 730's through 1070's. Late 70 series blocks were beefed up above the pan bolts and I had to make a different lock plate for them.
INCase
08-03-2005 09:48:37
 Re: another tractor splittig question in reply to Tom (Ks), 08-02-2005 18:32:23
Thanks for the ideas. I had wondered about taking the pan off and using some of the holes there too. Is it better to roll the front away from the rear or vise/versa? Thanks again!
TripleRange
08-04-2005 10:25:46
 Re: another tractor splittig question in reply to INCase, 08-03-2005 09:48:37
Most people roll the rear and leave the front. Big tires are easier to grab and turn than small ones.
1031D
08-03-2005 20:47:52
Well, I was at my CASE dealer yesterday, and they had a 2390 in there with the rear end rolled away from the engine. If they do it that way, it must work.
S.jewell(630 crazy)
08-03-2005 14:42:28
I have the splitting manual for the 630, I think their are picture and a diagram to build a stand. I will check it out tonight and get back with you.
S.jewell(630 crazy)
08-06-2005 09:52:32
 Re: another tractor splittig question in reply to S.jewell(630 crazy), 08-03-2005 14:42:28
I check the Splitting manual for my 630 and they show the stand for the back half. The front they used a special bracket that bolts to the valve cover bolts and suspends the front end with an overhead hoist... there where no rollers on the back half so I am guessing that you roll the front end away from the backend. If you want I can send you pic�s.
