Hydraulic top link for 401
PA CASE
08-02-2005 05:37:15
Hello,
I finally got to put my Case to work over the past couple of weekends. I got a boom lift and a 60" Woods Brush Bull for it. The Woods works great! When trying to lift old farm equipment with the boom however I ran into a problem. It hooks up to the eagle hitch just fine but with the standard top link it"s pretty worthless. The boom just pivots on the top link and the end only lifts a few inches. Is there a way to replace the standard top link with a hydraulic one so I can get more lift with the boom?
TIA for your responses.
Mike
Eldo Case
08-03-2005 10:19:24
 Re: Hydraulic top link for 401 in reply to PA CASE, 08-02-2005 05:37:15
You need the top link mounting bracket that goes over the pto. With it you can't use the pto shaft on the eagle hitch tractors 400,700,800,730 and 830. The only other way is to extend the top link higher on the equipment you use on it.
Jim B
08-02-2005 16:56:14
I'm not familar with your 401 but my 800 & 830 use a bolt-on upper link mount for the cat. 2 3-point. It's a casting that bolts over the PTO shaft eliminating use of the PTO but making the lift capability normal. Perhaps someone who knows 401's can verify if there were the same.
PA CASE
08-03-2005 08:26:01
 Re: Hydraulic top link for 401 in reply to Jim B, 08-02-2005 16:56:14
Just to clarify. I don't have any issue with the PTO being in the way as others have reported. My Eagle hitch arms lift nice and high. The problem is the top link only retracts by turning it by hand and under load this becomes impossible. If there is a way to add a hydraulic top link activated by the upper hydraulic hoses that would enable my boom lift to raise much higher.
Mike
Bret4207
08-03-2005 15:08:25
 Re: Hydraulic top link for 401 in reply to PA CASE, 08-03-2005 08:26:01
PA Case- They understand, they're giving you the info on how to try and make the Eagle hitch work with the standard 3 pt stuff. I have the same problem on my newly aquired 811B. I couldn't lift a round bale high enough with a bale spear to carry it away. I ended up cutting the easr for the top link off the spear and mounting them higher. It helps alot. I'd prefer hydraulic top link too for this. I have to do some measuring before I can figure what length cylinder I'd need. The problem with the Eagle hitch is the lift arms are much shorter than the standard 3 pt and the top link mount point geometry is different. Greater minds than mine can explain the math part from here on in.
PA CASE
08-06-2005 06:40:28
 Re: Hydraulic top link for 401 in reply to Bret4207, 08-03-2005 15:08:25
I think I"m beginning to understand myself. My BIL and I are gonna try to come up with a hydraulic solution. I"ll post back if we"re successful.
Thanks again everyone,
Mike
