I have Case Vac that is giving me trouble.
Nicholaus Sowde
08-01-2005 17:05:55
I have Case Vac that is giving me trouble. It would hand crank and turn over with the starter just fine now it won't even turn over with all of my weight on the hand crank. I took the starter off thinking it might have hung up. It hasn't been that long since I turned it over. Thanks
Ryan - WI
08-02-2005 18:23:42
 Re: I have Case Vac that is giving me trouble. in reply to Nicholaus Sowder, 08-01-2005 17:05:55
Did it sit outside in the rain? If enough water got in a piston you could have a hydraulic lock.
F-I-T
08-02-2005 12:28:31
Nicholas:
First thing, take out the four spark plugs. With no compression you should be able to flip it over pretty good. Hopefully it is just stiff. If not, post again and we'll go from there.
Frank
