power steering pump internal leak
timg
07-31-2005 03:46:54
I believe My power steering pump is leaking in the crankcase. Is this a common problem?
Can the pump seal be replaced with out special tools?
Jim B
07-31-2005 20:09:51
 Re: power steering pump internal leak in reply to timg, 07-31-2005 03:46:54
What model Case Tractor do you have?
timg
08-01-2005 02:47:41
 Re: power steering pump internal leak in reply to Jim B, 07-31-2005 20:09:51
580B backhoe loader w/188 diesel 2wd
Jim B
08-01-2005 17:45:35
 Re: power steering pump internal leak in reply to timg, 08-01-2005 02:47:41
Not sure about your 580B .... I had a similar problem with my much older 580CK w/188 Diesel which has a timing gear driven power steering pump. But mine was leaking crankcase oil into the power steering system. Constantly over filled the reservoir and contaminated the fluid. Easily repaired by replacing an O-ring behind the drive gear. No special tools required. Not sure that will help with your 580B.
