VAI and Eagle Hitch.
Mike (SC)
07-27-2005 18:32:00
I have a 49 VAI and found an Eagle Hitch off of a 50 VAC. Will the hitch off the 50 VAC work on my 49 VAI just from unbolting off the 50 VAC and rebolting on the 49 VAI or are different brackets involved. Thanks
Arthur
07-28-2005 06:20:42
 Re: VAI and Eagle Hitch. in reply to Mike (SC) , 07-27-2005 18:32:00
If your 49 already has an Eagle hitch, it will swap out...
Jerry W
07-28-2005 00:13:51
The Eagle hitch mounts down to a built up and machined area on top of the rear end housing. Most tractors that did not originally have an Eagle hitch do not have this machined platform and a changing out of the rear housing is usually also required.
Jerry
