R R a hydraulic cylinder on a VAC
Dave
10-11-1999 10:26:28
I have hydraulic fluid coming out of the breather unit near the steering column when the 3 pt hitch has a load on it. The service manual states the problem is in the cylinder and that the seal and o-rings need replacing. The repair looks easy in the book, anything I should be aware of? Any Tips or tricks out there? What type of fluid should I put back in the system? Thanks!!
Mike
10-29-1999 10:15:25
 Re: R R a hydraulic cylinder on a VAC in reply to Dave, 10-11-1999 10:26:28
If your looking for tecnical info. three's an I&T manual that covers the VA, LA, S, & C series tractors. Its pretty basic but covers the important stuff. The oil reccommended by the dealer is thier own Hy-Tran for both the hydraulics and the gearbox. Good luck!
Jerrie Lott
10-11-1999 18:16:03
I don't about tearing it apart and putting it back together, but the owners manual calls for 20 weight Hydraulic oil.
