VC and CC questions
Nedd
07-25-2005 06:46:07
VC brakes are they disc or band? Have rod going into housing. I also saw somewhere that they had more power then VAC, is that right?
CC has no rocker arm oilers?
Drove my brothers CC he just bought a couple weeks ago. Sat 10 years, drained old gas, checked oil and radiator, pop off within 5 feet. and purred. Will be going thru other fluids and restoring it ASAP. Too hot lately!!!
Alberta Mike
07-25-2005 17:44:18
 Re: VC and CC questions in reply to Nedd, 07-25-2005 06:46:07
The V series had sort of a clutch-style brake setup with a floating disc between a moveable pressure plate (that you activate) and another one inside that is attatched to the differential housing. You've obviously got to pull off the axle housings to get at them. Probably real ugly in there too, it's a big job. Get yourself a manual or be prepared to take lots of photos and draw pictures and label parts when pulling the brake setup apart. When you pull the axle housing off, the outer pressure plate assembly (with it's parts) will come off with the housing, the floating disc hangs on the axle shaft.
Mike in UP of MI
07-27-2005 14:51:43
 Re: VC and CC questions in reply to Alberta Mike, 07-25-2005 17:44:18
Mike, did you replace the brake lining when you did your brakes? Are the linings still available? Thanks, Mike
Alberta Mike
07-27-2005 15:32:20
 Re: VC and CC questions in reply to Mike in UP of MI, 07-27-2005 14:51:43
No, the linings were OK, well they were good enough. Had I needed them, I would have taken the disc to a good brake and clutch shop for relining but that gets very expensive these days. I did replace all the seals, etc. I soaked the linings in laquer thinner a few times, then brake cleaner and then roughed them up a bit with coarse sandpaper. They work pretty good now.
Brian in Ohio
07-25-2005 12:23:24
On the CC...
There were not rocker arm oilers that had oil pumped up to them. They had to be manually oiled once a day when they were a full time working tractor.
