Case 801B
caseman-d
07-24-2005 20:39:46
Good Evening,
I have a couple of questions concerning my Case 800. 1st, 2 years ago I parked the tractor beacause the line from the front of the tractor to the valve one the left side of the tractor started leaking. Finally after sitting 2 years I put a new line on it. Now I don't have presure to run the clutch pedal. Pressure drops when i push clutch pedal down and comes back up when I pull the clutch back with my foot. Any ideas folks.
2nd, Does the eagle hitch actually have down pressure. I don't seem to have any. I have hose running to bottom and one to the top. Hoses are hooked to the top portion of the valve. Is there a valve that needs to be turned? Let me know what I may be doing wrong. Thanks in advance.
caseman-d
Jim Nuhfer
07-25-2005 12:49:22
 Re: Case 801B in reply to caseman-d, 07-24-2005 20:39:46
The Eagle Hatch has down presure: 1) In the full forward position, maximum lifting speed is attained. 2) In the rearward float position, the eagle hitch drift arms are lowered by the weight of the implement. 3) In the MID position between neutral & full rearward, Hydraulic Down presure is applied to lower the mounted implement. (Note: the lever must be manually held in this postion until the lowering cycle is completed. If the lever is released in the mid-postion it will return to neutral automatically.)
c hess
07-25-2005 06:51:28
You said you need to pull up pedal with your foot. There should be a spring under foot rest doing that. Should be about 3/4 in in diameter an 2-3 in long. As for down pressure they did have limited down pressure. Pressure was not asgreat as lifting pressure. Iam sure you should have hoses connected to bottom two ports on valve. Left bottom should have a longer connection that can be adjusted for rate of drop.
