SC carb problems
JDGnut
10-10-1999 22:12:16
I've been working on a friends SC Case, its an earlier model (before 52, I think.) I am having problems with the carb.(It has a Zenith on it.) It seems to spit and sputter with the choke all the way off, which means that I'm not getting enough fuel. But I don't know where. I can make it run fair by pulling the choke out a little. I also can not adjust the idle screw (the upper screw on the carb.) I can turn it all the way in or all the way out with no change to the engine. I can even remove the screw with the engine running and no change. I have had the carb a part about ten times. I have taken all of the plugs and orifices out and cleaned and poked and found nothing. Have I missed some secret passage? Or is there a place that I need to look for problems in this carb? The tractor runs ok but we have to run the choke all the time, and don't think that is getting its full power, due to this problem. Thank you for any help.
JDGnut
Motec Engineering
10-12-1999 11:12:30
 Re: SC carb problems in reply to JDGnut, 10-10-1999 22:12:16
Take the carb off and send it to:
Motec Engineering
7342 W State Road 28
Tipton, IN 46072
765-963-6628
We will clean it, replace whatever needs replacing, and repaint it. We will then run it on a tractor and dyno. We will adjust it and make sure it works perfect. All of this will only cost $50.00 (includes shipping)
JDGnut
10-11-1999 20:35:37
I did forget to mention that it has new plugs and wires. The cap seems to be good, no moisture inside. It doesn't backfire, just misses. When you pull the choke out it seems to run OK, not missing, but I don't think that it is running as good as I know it has in the past. I have not had a chance to look for the intake leak, and I hope that this is not the problem, as I don't think this manifold has been off in 40 years.
Thanks for your help, guys.
JDGnut
Larry
10-11-1999 10:07:46
Sounds to me that you have an air leak some place. Check the butterfly shaft to see if it is lose,sometimes the shaft or the hole get worn and leak air.The best way I found to find manifold leaks is to run tractor at an idle. Then spray carb cleaner or WD40 around all mateing serfaces.(between manifold and head etc.) When the engine speeds up that is where your leak is. Good luck :)
mark
10-11-1999 06:53:32
It may not be a carb problem after all. I had similar problems on old equipment ( 1950's SC)and did all the same things that you listed. I found that the ignition timing was the problem. Check the point setting and timing.Replacement of the spark plug wires usually makes a difference, especially if the existing ones are leaking to ground (or even worse, to each other).
JDGnut
10-10-1999 22:22:42
Or do I have an intake leak that I'm just not noticing??
JDGnut
Marshall G.
10-11-1999 11:28:12
 Re: Re: SC carb problems in reply to JDGnut, 10-10-1999 22:22:42
My 1950 sc has a high speed adjustment on the bottom of float bowl. If your carb has this try a setting between 3&4 turns then adj. for highest rpm at wot.
