DC Foot Clutch Specs Wanted
Glenn FitzGeral
07-22-2005 08:44:05
I have adjusted the three 'fingers' on my foot clutch by sight, and it is now releasing. However I am still getting a little drag. What should the tollerance for the fingers be? Thanks, Glenn F.
L.Lamp
07-22-2005 21:43:01
 Re: DC Foot Clutch Specs Wanted in reply to Glenn FitzGerald, 07-22-2005 08:44:05
The information you want is in the "I&T Shop Manual C-201" on page 121. With the pressure plate installed on the flywheel the hub of the clutch cover is the reference point for each release lever. A straight edge held perpendicular to the hub should just touch each lever contact point when properly adjusted. Each release finger should be no higher than the height of the clutch cover hub. Did you test the springs? The early springs were 195-205 pounds at a compressed height of 1 13/16. The newer springs were 245-255 pounds at 1 13/16. The new springs were painted red to tell them apart. If you have red springs you have the late style clutch pressure plate assembly. Good Luck! If you find another foot clutch assembly let me know. Thanks. Larry
Don Rudolph
07-22-2005 19:27:12
Glenn,
Did you find a clutch pulley brake adjusting collar? I am sorry it took so long to get back to you-have been on the road steady. At least I don't have to look at the crops when I'm gone!
Don
